New member Username: Kickercvr10
Lincoln park,
Michigan
United states
Post Number: 1 Registered: Feb-06
Posted on CAN A MONOBLOCK AMP RUN TWO KICKER SUBS OR JUST ONE |
Silver Member Username: Goatin
U.S.A
Post Number: 358 Registered: Jan-06
Posted on both it depends on configuration and coils and ohms and that stuff. You need to be more specific... |
Lincoln park,
Michigan
United states
Post Number: 2 Registered: Feb-06
Posted on can you run two dual voice coil 2 ohm cvr10's to a monoblock amp sorry |
Gold Member Username: Bestmankind
Los Angeles,
CA
Post Number: 2526 Registered: Oct-05
Posted on if that amp is 2ohm stable then you can. |
Lincoln park,
Michigan
United states
Post Number: 3 Registered: Feb-06
Posted on thanks this ish is gunna baaaaang
New member Username: Roy_t
Post Number: 7 Registered: Feb-06
Posted on Your system is gunna suck!! |
Los Angeles,
CA
Post Number: 2536 Registered: Oct-05
Posted on why is it gonna suck. i have heard a demo of cvr's. they sound very good and get loud. i did hear the cvr 12 but how much can the cvr 10s be? |
Post Number: 8 Registered: Feb-06
Posted on I have 2 MA audio 10" the pound hard!! Kickers suck! |
Silver Member Username: Night_mirage
AmmanJordan
Post Number: 154 Registered: Jan-06
Posted on okay guys but also it depends on amp power . what is exactly your amp ? your system is good , Do n't care |
Los Angeles,
CA
Post Number: 2538 Registered: Oct-05
Posted on you are kidding right? ma audio? lmao |
AmmanJordan
Post Number: 156 Registered: Jan-06
Posted on Roy.t what did you say ???? MA is better than kicker ?? i think your system is suck .. |
Post Number: 10 Registered: Feb-06
Posted on I even have a thump amp. I only spent 180 bucks on my whole setup too, And it will out pound those Kickers! |
Bronze Member Username: Roy_t
Post Number: 11 Registered: Feb-06
Posted on dont call me a lmao, what is a lmao? |
Los Angeles,
CA
Post Number: 2541 Registered: Oct-05
Posted on it means laughing my azz off. |
