Directed 600d
Username: Waterboy2289
Martinez, Georgia USA
Post Number: 42
Would a directed 600d be a good amp for two JL audio 12w3v2? The subs are 4ohm dvc. Here is where I am planning on buying it: http://cgi.ebay.com/Directed-Audio-600D-600watt-mono-Amplifier-ONLY-80_W0QQitemZ 5863083268QQcategoryZ18797QQtcZphotoQQcmdZViewItem
Is this a good price for a refurb and is this seller anygood?
Username: N2audio
Lawrence, Ks USA
Post Number: 595
It's a good amp, and that's probably the best price you'll find. Ikesound is ok as long as the item's in stock and since they're listing it on ebay you're probably safer than buying directly from the store.
Username: Lewass
Bloomfield Hills, MI USA
Post Number: 107
Lots of people on this forum recommend ikesound.com
Also, yes, for that price it is a great amp. BUT, those are high end subs you may want to get a high end amp.
Don't want to drop mad $$$$? - Buy that sh!t before someone else does!
Post Number: 43
Yea...I feel pretty safe buying from ikesound on ebay...that way it is much harder for them to screw me.
