Why is my RE SE sounding better than my AA Aresneal?
Username: Biggyg9712
Post Number: 202
i just got my 12 inch aresenal today and hooked it up, it sounds worse and doesnt get as loud as my re se. my setup is:
pioneer 770p
audiobahn a800t
1.8 cuft box tuned to 34hz
and for some reason the aresenal is worse, does anyone no why?
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 5505
Maybe there not as good???????????????
Username: Southern_bass
Paris, Tennessee U.S.
Post Number: 1629
lol chauncey..same thing i was thinking
Post Number: 5508
did u have a ported box with the se as well??
Post Number: 205
ya, i used the same box for both of them
Post Number: 5511
According to there site ur box is a little small, but not small enough to effect the performance that much. Also they rec. ur port be tuned to 35hz...I guess there just not as good..lol
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 2156
Arsenals have a higher Qts than SE's...try a larger box. ~2.25-2.5cuft.
Username: Baseball1187
Columbia, SC
Post Number: 579
do you have it wired correctly?
Username: Teddy21
Ann Arbor, MI USA
Post Number: 24
OH YEAH
Post Number: 5517
So not building the box to recommended specs will make it louder and sound better..Marshall..Upload
Los Angeles, CA USA
Post Number: 2425
mike don't you have the re se xxx?
Los Angeles, CA USA
Post Number: 2426
why doesn't this bump up?????
Post Number: 2162
i didnt realize AA recommended 2cuft for that sub.
actually...larger boxes tend to peak higher in SPL (in most cases). but when you get a box too big the subs will start to sound muddy.
Post Number: 5523
Ok that explain's it. Because when u recommend a box that big i was thinking to myself, i no it should get louder, but sound better??, But then again i no nothing about building boxes
Post Number: 206
ya i have the re se xxx, but anyways if anyone wants this sub..im selling it, it has about 10 minutes of use, if u want it just make an offer or email me at greghill9712@yahoo.com and if we can make a deal i can ship it out by tomarrow
Username: Lets_talk_sound
Post Number: 31
how much does a 12" RE SE run?, I think its the SE thats 600 rms.
thanks
Spencer
Post Number: 5526
Correct
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 1845
hmmm.... i know my avalanche sounded better than my SE... and the arsenal is suposed to sound even beter...
Columbia, SC
Post Number: 580
yea, something sounds funny...
Post Number: 211
ya, i thought it was funny to, i think its just the box that i have it in, thats probly why its not sounding good
Username: B101
Queen City, NC USA
Post Number: 1158
maybe the Aresneal needs more power to get going? If the box is close to specs, then it should not affect it that bad!
Post Number: 212
thats what i was thinkin but when i had it at high volumes it was kinda distorting i think so i dont no
Bob365
Mike, in your last post you say you have the RE SE XXX, what do you mean? SE? XXX?
The ported box you have is a little small.
The main thing is that you haven't broken in your sub yet. Honestly, if you've played it for 10 minutes or an hour, you haven't broken it it. I've played mine for several hours, and have noticed a distinct change in sound since I installed it. I'm not saying this will for sure change your mind, but it will be a fairer comparison.
When you say not as loud. how much quieter is it? If it's almost as loud, I could maybe see it. If it's a lot quieter, then there's something up.
Username: B101
Queen City, NC USA
Post Number: 1161
how much rms is your amp? & how much rms is the sub?
unless RE is better? =D
Post Number: 213
my amp is 800 rms and the sub is 750 rms, the se is only 600 rms and its getting louder, weird
Post Number: 214
my sub is an SE but was re-coned with the xxx cone, so therefore the se xxx, and the sub is almost as loud, on my HU, the pioneer 770p, i turn it up to about 42/60, and at that point the re still holds up good but the aresenal kinda distorts
Username: Rob_brown
Post Number: 248
I'm thinking that you have the amp wired to 2 ohms since the arsenals only come in dual 4 ohms and your your se may be a dual 2 ohm sub. If you wired the subs the same way then you aren't getting the same ohm load as the se.
Username: James1115
Ct
Post Number: 5065
I will buy it from you Mike, let me know what you want for it:-)
Post Number: 216
no, they are both dual 4 ohm, and my amp is only stable at 2 ohms
Username: Rob_brown
Post Number: 251
yeah, i see that. i guess the arsenal is just worse? i don't see how that could be though, if it could be used as a sit in for the avalanche. maybe something wasn't put together right, or you need to just let it break in more.
Post Number: 217
james, if ur interested, add me on AIM, my sn is greghill9712
Username: Rob_brown
Post Number: 252
if you turn it up that loud and it distorts your gain is set wrong. not all subs are the same, that could effect it, but i don't think it would make it less loud.
Post Number: 218
no, my gain is set right, my HU is 4v and thats what my amp is at
Username: B101
Queen City, NC USA
Post Number: 1166
?? question
2 dual 4ohm subs wired to what>? what ohm load ?
dual 4s can be wired to either 1 or 4ohm loads; thats without creating any voltage dividers.
cause u said u have a 2ohm amplifier.
Post Number: 219
ya, i have a dvc 4 ohm se, and a dvc 4 ohm aresenal, i only have 1 sub hooked upt o the amp, not 2
Post Number: 5527
I think he only has 1 dvc 4ohm sub
Username: B101
Queen City, NC USA
Post Number: 1169
ohh, lol, sorry...
Try a Treo TSX or SSI 15
Post Number: 221
i no, i feel so dumb, there was this SSI 12 on ebay, wnet for so cheap, i forgot all about it look: http://cgi.ebay.com/12-Treo-Engineering-SSi-Subwoofer-750-watts-RMS_W0QQitemZ586 2715354QQcategoryZ18803QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Post Number: 5536
Thats almost as bad as a Diamond Audio D9 for $98 with free shipping.
Post Number: 222
james, if ur interested int eh sub, it will be like around $200 shipped
Post Number: 1851
i'd bet 100$ that an arsenal without something wrong with it wont distort with 800w rms if its clean power. even at 1000w....
Username: B101
Queen City, NC USA
Post Number: 1172
something is wrong somewhere, 800 rms is alot of power.
Username: James1115
Ct
Post Number: 5069
$200 shipped for a sub you think there is something wrong with it? ummmmmmmmmmm I don't think so man. Plus you bought it for $160. you plan on markingup a possibly broken sub?
Username: Matt12490
Benicia, California
Post Number: 401
maybe its just not broken in yet... just a thought
Post Number: 225
it didnt really distort, just kinda lost some sound quality i think, i dont really now, i would call myself a rookie at car audio, but what i do no for a fact, is in the same box powered by the same amp and the same song at the same volume, the se was better hands down
Username: B101
Queen City, NC USA
Post Number: 1176
^^^he held all variables constant...
Username: Rob_brown
Post Number: 253
you can't only try one song man, different notes hit different on different subs, try other songs to see if it's still not as loud
Username: Six
Flint, MI U.S.A.
Post Number: 371
...Break it in. period. Give it a good 200 wrms for like 4 hour intervals.
When, I got my 15" arsez, I thought they were barely louder than my single 15" ava... 3 days of playing later, WoW. Huge Difference. I'm soon to be getting a Orion 2500D and I know they'll love every bit of 1000-1200 rms.
Username: Six
Flint, MI U.S.A.
Post Number: 373
WTF BUMP NOW!
Post Number: 5598
Well when you think about it, its all about what you like to listen to, if you don't like the sound of the arsez get rid of them..
Post Number: 227
ya i dont like the sound, thats why im selling it, im asking $200 shipped if anyone wants it, and i dont think there is anyhitng wrong with the sub, its not broken in i know that for a fact, besides that the sub is fine, and i payed $220 + $22.50 for shipping, that $242.50 not $160, there is nothing wrong with it i just like my re se xxx better and have no need for this sub now
