Silver Member Username: ShadylimitedxPgh, Pa Usa Post Number: 477 Registered: Apr-05 | ok so iam goin 2 start makin my 15 re sx box its goin to be 15.5h 34h 18d tuned aroudn 26hz an how much port do i need should i do a 4in. wide port or 3in. wide port its gonin 2 b a slot port |
Silver Member Username: ShadylimitedxPgh, Pa Usa Post Number: 480 Registered: Apr-05 | ? |
Gold Member Username: Southern_bassParis, Tennessee U.S. Post Number: 1115 Registered: Dec-05 | why you tuning so low ? |
Silver Member Username: B101Queen City, NC USA Post Number: 729 Registered: Sep-05 | ask Marshall... |
Gold Member Username: Southern_bassParis, Tennessee U.S. Post Number: 1119 Registered: Dec-05 | yea ask marshall he has a sx |
Gold Member Username: SouthernrebelMonroe, Louisiana USA Post Number: 1910 Registered: Mar-04 | that 4.34 cuft (gross) box it plenty large enough. try 40-50sq inches of port opening. also...try tuning to 30-33hz for daily SQ. |
Gold Member Username: Southern_bassParis, Tennessee U.S. Post Number: 1124 Registered: Dec-05 | i thought he was tuning wayyy to low |
Silver Member Username: Baseball1187Columbia, SC Post Number: 550 Registered: Dec-04 | 26 is a little low, but if you want to squeeze more SQ and lowend out of the SX, go for it |
Silver Member Username: PelonaPost Number: 182 Registered: Dec-05 | tuning at 26hz aint that low |
Gold Member Username: Southern_bassParis, Tennessee U.S. Post Number: 1157 Registered: Dec-05 | you dont see that on sx's much though |
Silver Member Username: ShadylimitedxPgh, Pa Usa Post Number: 482 Registered: Apr-05 | i like my boxes tune low cause it sound go0d an i like for ppl 2 hear me an vibrate everything when i go by lol an how do u get how much port u got an new messurement is 16h 34w 18d big enough |
Gold Member Username: SouthernrebelMonroe, Louisiana USA Post Number: 1915 Registered: Mar-04 | your new measurments show 4.49cuft (gross)...i am assuming that you are going to mount the sub on the 16" face. if so, your port can be 14.5" tall and 3" wide...that would give you 43.5sq inches of port. if you tune to 32hz...you can get ~3.75cuft net out of the box. (your port can be 14.5" tall and 3" wide on the 16" face...that would give you 43.5sq inches of port, ~24.5 inches long) i would recommend 32hz. if you still wanna tune to 26hz...try port 14.5"x 2.5"...37.5" long. this will only give you 3.4cuft out of your box though. i plotted the 32hz box and the 26hz box on WinISD and it showed that the 32hz box would be ~2.5dB louder at 35hz-40hz, and the two boxes would be equally as loud at 29hz. |
Gold Member Username: Southern_bassParis, Tennessee U.S. Post Number: 1219 Registered: Dec-05 | dang - nice |
Silver Member Username: ShadylimitedxPgh, Pa Usa Post Number: 483 Registered: Apr-05 | i guess i should just tune it at 32hz with the 3 inch wide port hey marshall ur pretty go0d at ur sh4t how do u get that program |
Silver Member Username: ShadylimitedxPgh, Pa Usa Post Number: 484 Registered: Apr-05 | 30hz or 32hz |
Silver Member Username: Baseball1187Columbia, SC Post Number: 551 Registered: Dec-04 | 32hz would be best. I had my SX at 27-28hz and it was a little low. Plus, most people's idea of "low bass" does not dip below 30hz, so you're not losing anything there. My friend's 12" SX is ported at 35hz, and it still does a nice job gettin' down low. Pelon - I know 26hz isnt that low, but it is for an SX. If I were to build another box for an SX I would go with 32-35hz for daily. |
Gold Member Username: James1115Wilton, Ct Post Number: 4699 Registered: Dec-04 | Hey pelon 26 is infact very low for a tuned box! the human ear can't hear freq below 18-20hz and that great hearing. Now when you set a subsonic filter you set it at about 5hz below tuning so you would set it at about 21hz. That doesnt leave much more musicto be squeezed into that 1-3hz that you would be missing! |
Gold Member Username: James1115Wilton, Ct Post Number: 4700 Registered: Dec-04 | I agree with Baseball and Marshal tune to 32hz with that particular sub and you wont be unhappy with the output |
Silver Member Username: ShadylimitedxPgh, Pa Usa Post Number: 485 Registered: Apr-05 | should i go wit a slot port or 2 tube ports |
Gold Member Username: SouthernrebelMonroe, Louisiana USA Post Number: 1925 Registered: Mar-04 | 32hz is great for daily w/ the SX15 http://www.linearteam.dk/default.aspx?pageid=winisdpro there's a link for ya...its a great progam. but i does take into account port displacement, you have to figure that in for yourself. |
Silver Member Username: ShadylimitedxPgh, Pa Usa Post Number: 486 Registered: Apr-05 | all i lisiten 2 is rap so will the 32hz do |
Silver Member Username: ShadylimitedxPgh, Pa Usa Post Number: 487 Registered: Apr-05 | will the bass be so loud so when i drive passed ppl they look i lisiten 2 rap an my whole car is almost complete wit the sound dampin i just wat ppl 2 look an say wow |
