Do 4 channel amps have a X-over for each channel
Username: Blainew
Post Number: 636
can you hook up subs to 2 channels, and speakers to the other two????
Username: Blainew
Post Number: 637
my bad wrong section
Username: Rovin
Trinidad & T...
Post Number: 4690
well ur answer is still yes -lol ........
Username: Blainew
Post Number: 642
but....would the amp crossover really go down to below 100 HZ??
Username: Rovin
Trinidad & T...
Post Number: 4692
well 1stly ur amp has 2 be a good brand & not some econo generic full range amp
i'm darn sure on my alpine 545 i saw it goes down low - i could check it back 4u 2morrow , i'm running 2 pairs of Inf 6.5" Ref comps off my amp .....
Username: Rovin
Trinidad & T...
Post Number: 4695
i'm darn sure on my alpine 545 it goes down low , i'm running 2 pairs of Inf 6.5" Ref comps off my amp .....
Username: Tjmutlow
Post Number: 1001
before you start hooking upm subs, make sure the ohm load is correct, 4ohm bridged for a 4 channel and 2ohm stereo. just dont start bidging.
Username: N2audio
Lawrence, Ks USA
Post Number: 273
every 4 ch I've ever seen (that has a crossover at all) has a crossover for each PAIR of channels, and yes - it is common to run a 4 ohm sub off two bridged channels and use the other two for a pair, or two pairs of speakers.
