Question about qiring subs to 2 amps....pleasse help
Username: Blainew
Post Number: 557
okay so i will have two RE 12.1's
stable at 1 ohm
so i wire each sub down to one ohm and to each amp
but how do i do the RCA's...should i just put one to each amp...like the left one to one amp..and the right one to another amp???
does that make any difference .. having only one rca going to an amp???
Username: Blainew
Post Number: 559
i can just run one pair on rcas from the HU..split the left..split the right...so that i have four and ill be good right???
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 820
yes, just split the rca leads and you should be fine.
Username: Tjmutlow
Post Number: 940
do not split unless have to, use the line out on one amp to the other amp, most high end amps have them.
