Alpine Type E Sub
Username: Alpine4life
Post Number: 7
i have an alpine type e 10 inc sub with a alpine mrp m350 mono amp. any tips or suggestions on how to maximize its performace. oh yeah the type e sub is a 4omh coil sub. anymore info needed let me know.
the subs specs are as follows:
the type e specs are » 10" 4-ohm subwoofer
» Kevlar-treated pulp woofer cone
» high-excursion Santoprene rubber surround
» dual oversized Nomex spiders
» frequency response: 32-1,000 Hz
» power range: 50-250 watts RMS
» peak power: 750 watts RMS
» sensitivity: 87 dB
the amp specs are as follows"
» 200 watts RMS x 1 at 4 ohms (350 watts RMS x 1 at 2 ohms)
» low-pass filter (50-200 Hz, 24 dB/octave)
» variable Bass EQ bass boost (0-12 dB at 50 Hz)
» subsonic filter (15 Hz)
» MOSFET power supply
» preamp- and speaker-level inputs
» blue power LED
» extra-large gold-plated terminals
700 watts max power
Username: Greeney88
Http://www.freewebs.co..., Minnesota US
Post Number: 15
what kind of enclosure are you using (ported? sealed?)
Post Number: 13
sealed.
Details:
» hatchback style enclosure for one 10" subwoofer
» 3/4" MDF (medium-density fiberboard) with gray carpet covering
» spring clip terminals
» internal volume: .75 cubic feet
» cutout size: 9-1/4"
» dimensions: 14-1/2"W x 13-9/16"H x 10-5/16"D
