What are some good quality coaxial speakers?
Username: Dustin3
Tigard, Or U.S.
Post Number: 123
dont need them to be really expesive but i have 2 subs and need some better sounding subs that my old ones. can u make a list of some good coaxial speakers?
thanks alot
Username: Vinnyqh
Portland, OR
Post Number: 111
how much power are you gonna put to them? jsut deck or do you ahve an amp? If you ahve an amp i would go with diamond speakers d361i.
Username: Dustin3
Tigard, Or U.S.
Post Number: 125
just running off of my deck 45 x 4 watts. i have 2 subs so dont need a ton of bass from them.
Username: Dustin3
Tigard, Or U.S.
Post Number: 150
are their any brands or models that u can post so i can go toards i am looking at 5 1'4 or 6 1/2.
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 1410
if possible get a chaper comp set. IMO i hate coaxials because of the lack of a good crossover. if ur problem is that u dont have anywhere to mount a tweeter then 1, make a spot for them lol or 2, they have comp sets which hold the tweeter in the middle of the speaker.... they may be higher end though like i know cdt has some...
Username: Tjmutlow
Post Number: 599
Infinity refernece.
Username: Dustin3
Tigard, Or U.S.
Post Number: 160
how much are those?
Post Number: 1436
reference comp sets are like 100 on ebay...
Post Number: 1443
heres one idea of what i was tlaking about for cheap.
http://cgi.ebay.com/CDT-Audio-SALE-CL-60CV-6-1-2-Convertibles_W0QQitemZ581770459 1QQcategoryZ18800QQssPageNameZWD1VQQrdZ1QQcmdZViewItem
and then the more quality version...
http://cgi.ebay.com/CDT-Audio-EF-53NEO-5-1-4-Slim-Frame-Braxial-Speakers_W0QQite mZ5837148144QQcategoryZ18799QQssPageNameZWD1VQQrdZ1QQcmdZViewItem
Username: Dustin3
Tigard, Or U.S.
Post Number: 165
who is CDT, never heard of them??
are the infinity ref. good speakers for the price?? what are they origonally?
would the top link be good if powering off headunit? because my headunit is 45 x 5 watts and i am powering 4 speakers in all with HU
Username: Dustin3
Tigard, Or U.S.
Post Number: 166
for my HU being 45 x 5... what RMS of a pair of speakers would work well??
what model # is the best for the infinity ref?? there are a ton of diff models. or are they all pretty good.
Post Number: 1454
if u are permanetly going to run them off a hu u shud probably get the infinities. and ur HU is probably like 20x4 45x4 is the max power most likely... not positive though. cdt is cd technologies. they have great products but ive only heard results from people with the slightly higher end stuff from them...
Username: Dustin3
Tigard, Or U.S.
Post Number: 167
so what RMS for a pair of speakers should i get so i am not underpowering them but not overpowering them? and remember i am going to have 2 pairs so 4 total speakers so i dont want one pair of speakers to be more than all the other ones.
basically, i just want to know what RMS per speaker pair would work well.
thanks alot trev.
Post Number: 1463
i think the infinity reference speakers should be a good buy and they are only 100 so you cant really lose. i dont know of many decent speakers that are rated much below 75w rms. im sure i could find some if i looked really hard so if ur really determined... search! lol. but its okay to underpower them if u dont clip the signal...
Username: Dustin3
Tigard, Or U.S.
Post Number: 181
but what would be a good rms for a pair of speakers with my HU?
Post Number: 1472
what HU do you have anyways?
Username: Dustin3
Tigard, Or U.S.
Post Number: 185
kenwood kdc-128- so with this what rms for a pair of speaker should i go for?
thanks
Username: Suleman36
Maryland U.S.A.
Post Number: 2758
http://www.crutchfield.com/S-DmfxNrgbFIl/cgi-bin/ProdView.asp?g=400&I=1086012SI
That is the way to go for your case. You can either go with the 6.5 or the 5 1/4 size. They work very good of HU power.
