How do i extend the wire form the tweeters
Username: Williestylez85
i just baught some tweeters and the wire is short can i just use regular speaker wire that you use for subs to extend the length. i plan on hooking them up in the back of the nissan.
Username: Delishious
you should use the same size wire that the tweeter has.probably 18 guage.
Username: Tjmutlow
Post Number: 744
use around 16 guage and crimp cap or blue butt then togrether and then wrap on black tape,
16 gauge will work too.just check wich size looks more similiar to the tweeter wire and get it
