Bright 4 inch coaxials
Username: Pelona
Los Angeles, CA
Post Number: 30
what are some good 4 inch coaxials? i want them to have the brightest tweeter and not be power hungry because ima power them off the head unit which is a pioneer 22rms x 4.
Username: Tjmutlow
Post Number: 717
infinity reference, (use bass blocker on them)
Username: Pelona
Los Angeles, CA
Post Number: 33
but arent the kappas brighter?
Username: Tjmutlow
Post Number: 730
they are a 2ohm speaker, dont recopmend unless your running an amp.
Username: Pelona
Los Angeles, CA
Post Number: 34
oh yeah they are 2ohm. but what about boston acoustics and mb quarts. i heard they can be bright too.
Username: Tjmutlow
Post Number: 732
how much do you really want to spend on 4's you only get so much out of them....
Username: Pelona
Los Angeles, CA
Post Number: 35
well thats the only size that fits on my car.i dont really care about the price. i think ill stick with the references.
oh, one more question.do the references have a metal dome tweeter. i heard those are brighter than a silk dome.
Username: Tjmutlow
Post Number: 735
they are silk, but i think you will be ok with them, if need xtra tweets and a seperate set of reference tweets.
Username: Pelona
Los Angeles, CA
Post Number: 37
in some of my friends cars they had 4 inch RF punch and another had a 4 inch RF power they both sounded loud and bright and they were powered by the head unit.
how do those two compare to the reference?
