Hz?
Username: Lexuscoop
Post Number: 429
do the makers of the subs tell you like a recomended Hz to put the subs on? for like best SQ and SPL or do you pretty much have to find it your self?
Username: Araknid
BOCA , FL U.S.
Post Number: 1467
A Hz is a is the unit used to measure frequency.
1 Hz is from a stand still position, To positive, then negative, then back to stand still position. measured per second.
Do you mean what Hz to tune your enclosure to?
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 720
if your talkin about what to tune ports to, then usually they do. usually give you reccomended deminisions and everything too. its gonna be a general use figure most of the time though, inbetween SQ and SPL
Username: Araknid
BOCA , FL U.S.
Post Number: 1468
When they say a Port is tuned to a certain frequency or Hz. Thats the frequency at which the Sub and the Port become equal. Or in simpler terms the loudest.
Username: Lexuscoop
Post Number: 431
yea, like you know some subs sound better at like 45 Hz than they do at lets say 40 or 50Hz? you know what i mean?
Username: Lexuscoop
Post Number: 432
not a ported, sorry, didn't mean to say SPL, just ment for SQ... my bad. but do you know what i mean by like maken them louder and sound better? i dont' know if im explainin it the way i mean to
Username: Kwrubel21
Shelby Township, MI United States
Post Number: 91
i've got a question too.
is there any specific thing you have to do to tune a box at a certain level. or is it just the size of the box that makes it tuned at a certain level??
Username: Araknid
BOCA , FL U.S.
Post Number: 1469
Kinda hard to explain but ill try.
The internal volume of the enclosure determines the the tuning of the port. So say if you had a box Tuned to 35 Hz. Then you change the internal volume of the enclosure and kept the port the same dimensions it would be tuned differently.
Username: Lexuscoop
Post Number: 435
oh ok, so like if you change the Hz, you change the box, figuratively speeking? if you change the box you change the Hz, or do i have it wrong, im pretty sure i have it wrong... if the box dementions were 1 cubic foot, per sub, and you have two, in a closed enclosure, would you have to search for the best Hz, or would the directions tell you? if you guys understand that
Username: Araknid
BOCA , FL U.S.
Post Number: 1470
Ok the way I explained it was confusing.
Your port dimensions depend on the internal volume and what frequency you want your port tuned to.
Username: Lexuscoop
Post Number: 436
ok, so the Hz you want to tune you sub, it all depends on your enclosure?
Username: Araknid
BOCA , FL U.S.
Post Number: 1472
No it depends on what you want it to be. Like if you listen to alot of music in a certain frequency band.
Say 50-60 Hz. Or If you want to tune to your car's fresonant frequency for a comp.
Username: Lexuscoop
Post Number: 440
would rap be in the lower Hz or mid?
Username: Araknid
BOCA , FL U.S.
Post Number: 1473
All rap is different.
Username: Araknid
BOCA , FL U.S.
Post Number: 1474
I woundn't recommend tuning to match certain songs though cuz you play anything else it would sound like garbage.
Username: Lexuscoop
Post Number: 442
true...so would i be better off, like puttin the amp under my seet so i can change it, or just leave it to what sounds good?
Username: Araknid
BOCA , FL U.S.
Post Number: 1476
But You really should never tune too high unless your goin for straight SPL. Otherwise keep it below 45 Hz.
Username: Lexuscoop
Post Number: 445
ok, so more Hz the better for SPL and lower for Sq?
Username: Araknid
BOCA , FL U.S.
Post Number: 1477
Woah dude me and you are talkin about 2 completely different things. Thats the Low Pass Filter. IM talking about port tuning. Your Low pass Filter should be at about 100 Hz. That means it will play all frequencies below 100 Hz.
Username: Lexuscoop
Post Number: 447
LOL sorry, i didn't know what i was talkin about, so i confused you. ok, so the low pass filter is on the amp correct, and if so, i should tune the amp to 100Hz, so it will play 100 and below, correct?
Username: Araknid
BOCA , FL U.S.
Post Number: 1478
Yes
Username: Lexuscoop
Post Number: 448
lol ok thanks, lol... long conversation about that when the answer was just a yes... lol... sorry if i was like annoying you, you know?
