Will my old power wire work for a new amp?
Username: James_garrett
Bentonville, AR
I have purchased a 1000watt RMS amplifier to replace the little piece of junk that I already have and am wondering if the 10awg wire that is already in the car will work. The new amp will hold up to a 4awg wire so I don't know which way I should go.
Username: Blainew
Post Number: 281
10awg is to small..if 4 awg is the biggest it will hold...get 4 awg..10...ur car may light on fire
Username: Rovin
Trinidad & T...
Post Number: 3698
Power cable guide
http://www.the12volt.com/wiring/recwirsz.asp
Bentonville, AR
Post Number: 8
Thanks
Username: C10_250
Does anybody know if 2g would be acceptable to run to an auxilary battery in the trunk?
Username: Tjmutlow
Post Number: 340
yes
