Help!
aSJSJ
my pioneer tsw306c subwoofer is making a fluttering noise like from 1-3 feet away i hear the fluttering and no bass and when i get further i hear it less.it sounds like the speaker is moving without making bass noise just the flapping like noise.I am powering it with a 150 watt amp.th e noise only happens when i turn thr volume a little over half
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 1725
check the ground on your amp...make sure you have a good connection.
also, your gain may be set too high.
