RE 12 vs KAPPA PERFECT 12.1D
James Palanza
SQ and SPL wise, which do you think is better?
That RE12 is 175 RMS while the Kappa Perfects are 350 RMS .. I can get em both for 70 bucks, which is better?
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 2717
i would go kappa perfect, if u can power them properly
Username: Insearchofbass
Post Number: 3817
have you heard both chauncey?
Post Number: 2836
yep
Post Number: 3818
did the re beat the infinity in any way?
Username: Ilyawizard
Post Number: 10
I have the same kappas. What do you mean power properly? What would you recommend?
