Bronze Member Username: Drummer_boyFranklinton, Louisiana USA Post Number: 11 Registered: Nov-05 | My freind has a Chevy Sliveroda with the bed cut out to fit 4 L7 i told him he should just put 2 Solo X's in it, what do you think he should do |
Silver Member Username: UcfsaxmanOviedo/orlando, Fl Post Number: 320 Registered: May-05 | either one would be loud if your not concerned w/ sq i would say get the 4 it will look a little cooler. if he's goin for show 4 subs would look better than 2. |
Silver Member Username: Nutty91rsBloomington, Indiana USA Post Number: 246 Registered: Oct-05 | The 4 L7s will be superior in output, easier to power, and look cooler. If he doesn't plan on burning up and rebuilding subs at every comp stick to the L7's. |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 2016 Registered: Jul-05 | i have 4 l7's.lol |
New member Username: TrippinbarrPost Number: 1 Registered: Nov-05 | I was wondering if anybody knew where to find the spec to build a ported L7 speaker box |
New member Username: MobsterPost Number: 2 Registered: Nov-05 | kicker.com or the L7 manual. i need help with mine i have 2 12" L7's and it isnt too loud |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 2301 Registered: Jul-05 | willy what kind of amp do u have |
New member Username: MobsterPost Number: 3 Registered: Nov-05 | kicker 1200.1 but i had 2 10" L7's before the 12's and i traded them in for the 12's |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 2302 Registered: Jul-05 | what kind of box do u have, and do u have a HO alternator |
New member Username: MobsterPost Number: 4 Registered: Nov-05 | lol its sealed and definatly not to reccomended specs and i dont knwo what a HO alternator is? (i am going to build a ported box soon. lol thats what ive been saying for a while i just dont know the specs) |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 2307 Registered: Jul-05 | thats it then, ur amp can not draw enough current from ur alternator, and building ur box to recommend specs would help alot as well.btw i have 4 15 l7's and there are plenty loud |
New member Username: MobsterPost Number: 5 Registered: Nov-05 | man that must be so loud. have u entered any comps? and where would i get a high output alternator and i have a 1999 Subaru Outback and i donno how to build a ported box to fit my car. lol im a newb |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 2310 Registered: Jul-05 | no comps http://www.excessiveamperage.com/ They make great alternators, just give them a call http://www.klausaudio.com/ Great boxes |
New member Username: MobsterPost Number: 6 Registered: Nov-05 | my car hatch rattles alot and i dont want to buy dynamat . how do i "lessen" the rattling. also ive given up on sound quality so what "tricks" are there for SPL?? |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 2313 Registered: Jul-05 | i used edead v3 and it works great, almost no rattle at all. And im not sure of any "tricks" for spl.lol |
New member Username: MobsterPost Number: 8 Registered: Nov-05 | could i get that off eBay . i live in C a nada. lol |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 2320 Registered: Jul-05 | yep |
Gold Member Username: SouthernrebelMonroe, Louisiana USA Post Number: 1669 Registered: Mar-04 | peal-n-seal...its really cheap and you can get it at Lowes. or get edead. also, if you have a hatchback...try a CRX box (ex: subs firing up, ports back) and always test, test, test. |
New member Username: MobsterPost Number: 9 Registered: Nov-05 | peal-n-seal would it work as good as like eDead or dynamat? and so i was thinking subs firing towards the roof then have the port exit facing the hatch. |
Bronze Member Username: MobsterPost Number: 14 Registered: Nov-05 | ok i live in canada and so what hardware store would sell that peal-n-seal???????? |
