Head unit keeps shutting off
Username: Jwahrer
Post Number: 14
whenever i turn the volume up high the head unit just shuts off, what could the problem be?
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 2331
lack of current
probably need a bigger alternator, or smaller amplifier(s)
Username: Jwahrer
Post Number: 17
i am only running an alpine MRP-M350 amp to power my sub, other than that it is a JVC head unit pioneer 6x9's and pioneer 4x6's
when i had someone check it out they said that it was my front speakers, they said that they were wired correctly, but they also said that they were wired wrong.
Username: Jwahrer
Post Number: 18
the only amp that i am running is an alpine MRP-M350 to power my sub
Username: Glasswolf
Post Number: 2348
well if the amp or speakers are improperly wired, you need to fix that.
I've seen a 200 watt amplifier cause a car to completely stall out when the system was turned up.
the amp, regardless of size, is still a strain on the car's electrical system that the car maker didn't take into account when choosing the alternator size for the engine.
