Best Amplifier for SX 12?
Username: Kirbdog22
New Bern, North Carolina USA
Post Number: 43
Opinions on best amplifier for SX 12?
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 1888
Budget: Hifonics 1500d, audiobahn 8000T
Midgrade: Kicker kx 1200.1, Re 12.1
Moneys not a problem: Zapco 1100.1, JL 1000/1
There are lots more, these are just to give an example
Username: Kirbdog22
Post Number: 44
you told to me to try the Hifonics 1605D well you said that would be alright still think it wouldn't be to much? On the Realm of Excursion website people were using that same amp to power the XXX. I mean i am on a tight budget i do not want to blow the speaker by running to much power to it. Oh yeah what do you think the true power output of the hifonics 1500D is?
Los Angeles, CA USA
Post Number: 803
little over 900wrms.
Post Number: 1894
at 1 ohm its around 1050, hifonics put out about 70% of what they say. but still a good budget amp
Username: Kirbdog22
Post Number: 45
so go with the 1500 Hifonics for a good budget amp and would i should not have any problems running at 1 ohm stable?
Los Angeles, CA USA
Post Number: 806
you got it
Post Number: 1896
with that amp u would give the sx its recommended power so it will still work great
Post Number: 1897
btw how many amps is ur alternator
Username: Kirbdog22
Post Number: 47
i don't know i'll have to check the owners manual. oh btw if bass control is opt. on this amp does that i could order one or buy one when i have the amp installed? it is not expensive is it?
Los Angeles, CA USA
Post Number: 807
don't worry about blowing those subs. they can take alot.
