Amp rack fans
Username: Shawnomak
HB, SK Canada
Post Number: 150
i wanna make an amp rack with fans in it, i prolly dont really need it, but it looks friggin sweet, my question: can i just use computer fans for this? because i have two 5" fans with blue leds in them i want to use. also, do i need a fan that pushes air in and another that sucks it out, or can i use one to push air in, and have like a port for the air to get out? any ideas?
Username: 54danny54
Post Number: 1072
yes as for the comp fans....id go fans blowing in with a small port on the opposite side
Username: Mikechec9
Http://www.cardomain.c...
Post Number: 1640
i prefer the push-pull set-up. squirrel fans are my preference, but it really depends on how you have your rack arranged. but yes, cpu fans are often times used.
Username: Mixneffect
Orangevale, Ca. USA
Post Number: 586
For push/pull setups just wire one fan in phase and the other one invert the wires so that it spins the other way.
Just incase you wanna try that.
