SQ???
What is SQ. Does it mean the higher you can put a subs volume with out distortion the better SQ? Or is it the surround sound you get from subs??
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 1660
sound quality, who good it sounds, how high ur subs can go without soundin like crap
Los Angeles, CA USA
Post Number: 568
then what is the difference between sql and spl?
frkkevin
Going loud and sounding good with little distortion // going outragiously loud with poor sound quality some distortion
Los Angeles, CA USA
Post Number: 569
thx frkkevin. why don't you register? i see you on here alot.
Post Number: 1669
i think if u post more than 10 times u should be forced to register.lol
Username: Frkkevin
Fort Worth, Texas US
there :P.. now help me! before i loose sanity! lol
