Testing a used HU?
Username: Jmjacks
Eaton, OH United States
Post Number: 8
Whats the easiest way to test a used cd player to see if it works without actually hooking it up in a car?
Username: Illuminator
Post Number: 2188
Hooking it up to a regulated power supply that puts out 12v DC at about 5-12 amperes (You can go with more amperes if you prefer).
Example:http://cgi.ebay.com/Astron-RS-12A-12-volt-DC-Power-Supply_W0QQitemZ5827166490QQc ategoryZ15051QQrdZ1QQcmdZViewItem
There are positive and negative binding posts on the back of the unit that allow you to hook up the head unit power wires to the power supply.
