New member Username: TomdamanPost Number: 4 Registered: Apr-04 | I putting 2 12" eclipses sw8122.4 in a ported box. I dont know how much room I need. |
its not bacon12 Unregistered guest | you need 13.975 cu ft per sub thomas hope youve got a big trunk |
New member Username: TomdamanPost Number: 5 Registered: Apr-04 | Alright, and what about the box its self. Like how much room do I need in the box for the subs. Some of the boxs im looking at have 3.47 cu. ft., 2.65 cu. ft., and 1.63 cu. ft. which one would be best for these subs? |
its not bacon12 Unregistered guest | 2.65 cu ft tommo, it'l sound tight man. |
Gold Member Username: GlasswolfNorthWest, Michigan USA Post Number: 2129 Registered: Dec-03 | http://www.eclipse-web.com/products/speaker/sw8100/sw8122dvc.html anything in the 1.6-2cu ft per sub range is fine for ported. They do extremely well in a small sealed box, too.. very tight, very low. |
New member Username: TomdamanPost Number: 7 Registered: Apr-04 | how many cu ft for the sealed? |
Gold Member Username: GlasswolfNorthWest, Michigan USA Post Number: 2172 Registered: Dec-03 | 0.7 to 1.0cu ft per 12" as I recall. |
