Sony XR-C5120R
JBroadsword
Hi - ive just bought a car and i can't get the stereo to work.
The car was bought form a friend and i knew it played up a bit (as my mate has had problems) but no matter how much i fiddle with it and clean it nothing happens.
I can insert a cassett and the mechanism takes it in, but it doesn't play and the head unit doesn't light up. I can eject the cassett - but again nothing else happens.
Has anyone else had a similar problem with this particualr head unit? Or can anyone please offer any advice? Failing and tips i guess the garage is the next call.
The unit was bought and fitted in 1999 and has worked really well because i've heard it!
Thanks for your help.
Username: Illuminator
Post Number: 2125
Did you check the fuses?
JBroadsword
Hi - yes, all the fuses have been checked and all are ok.
I've taken the unit out fully too to make sure there are no loose connections, and all's well there also.
Post Number: 2139
The unit itself might be dead. They aren't too expenisve to replace...so that might be your best option...
JBroadsword
thanks. I think thats the way i'm gonna go.
cheers
