Bronze Member Username: Eddyg519Post Number: 19 Registered: Oct-05 | hey everyone. I need to know if a power acustic (spelling?) amp are better then Hifonics. Im considering getting some kicker amps because im getting kicker subs but i do want to save some money at the same time so my question is this. Are Hifonics and PA amps OK ? and how many kicker amps do i need to power: 2 10" L7's 4 15" L7's thanks kindly! - Eddy |
Bronze Member Username: Eddyg519Post Number: 20 Registered: Oct-05 | can anyone help me out here? |
Gold Member Username: RovinTrinidad & T... Post Number: 1477 Registered: Jul-05 | http://pub14.ezboard.com/fcaraudiotalkfrm27.showMessage?topicID=27.topic the Hif are 'ok' if u are on a tight budget |
Silver Member Username: James_gTN Post Number: 330 Registered: Jul-05 | Two 10" L7s and four 15" L7s? Is this a daily driver? Have you considered the power you need for these subs? I'm just curious. What size alternator will you be using? |
Silver Member Username: UcfsaxmanOviedo/orlando, Fl Post Number: 210 Registered: May-05 | if your gonna do those kind of subs you should do 4 10's and 2 15's. it would sound better IMO. I would say Hifonics is a little better than Power acoustik. w/ only 2 10's they would be worthless and you'd be better of just getting 1 more 15 and having 3. but w/ 4 10's going you could have the 15's to take care of the low end it would work better than the other setup. |
New member Username: Jake110011Jackson, Michigan Post Number: 9 Registered: Oct-05 | I would run Hifonics over Power Akoustik |
dayton, ohio Unregistered guest | hey guys i have an 01 nissan pathfinder i am planning on getting the kicker L7 sub 2 ohms with the kicker sx650 amp and using 0 gauge wire, however my battery died on me so i went out to sears and got a new die hard gold battery installed and i was wondering if i would need to purchase a capacitor for the system or not and if so would a 1 farad work fine? so i was just wondering if someone could help me out with it that would be great thanks |
