Is the mounting depth on a 2004 10" Type are more shallow than the new 2005 models? i looked on the website and it looked like the mounting depth on the '04 models were 6" or so...but the new ones are 7"??? whats the deal? I have to have a sub with a max depth of 6.5"....i guess i will have to go with the CVR10 if the Type R wont work
Well I am not too sure about that but I do know that Alpine changed the Type-R from 04 to 05 to accomadate more power handling and changed the surround...it is quite possible that increase in power handling forced a larger magnet structure which made the speaker larger thus calling for a deeper mounting. I have personally used the CVR12 and they are pretty good but if you can work it out I would go with the Type-R...my current set up...I think you would be happier.
