RE re?
Username: Hondarider
Glidden, Iowa U.S.
Post Number: 82
Do these subs get loud with only 175 watts rms?
Do they sound good?
Glidden, Iowa U.S.
Post Number: 83
And will they handle more 175 watts? If they can how much?
Username: Robert_d
MIA, FL USA
Post Number: 212
alot of people who have them push 225rms through them there nice sounding subs from what ive heard im not sure what you consider loud but they will put out some kick
if u want some loud subs get a SX alot of people say they get louder than the L7's and still have a nice sq for a spl sub
Username: Taylor17
Kopperl, Texas
Post Number: 3182
I wouldn't go over 250 watts rms... thats about all I'd be willing to push them with.
Like Robert said, depends on what you're calling loud, but I'd say the get loud for they're power requirements..
Username: Killerzracing71
Fredericksbutg, Virginia United states
Post Number: 97
hey did you guys forget a zero i am confused 250rms is that 2500rms or what
Username: Thigpen
RVA, Va Usa
Post Number: 149
ummm i dont think youd be giving a RE RE 2500rms so no i dont think they forgot a zero
Username: Jakeyplaysbass
Post Number: 79
killerzracing you are thinking of the MT most likely the RE re is there entry level sub. the MT is there comp. SPL sub.
Username: Taylor17
Kopperl, Texas
Post Number: 3204
Lol... you're thinking of the RE MT.
The RE series has an rms rating of 175 watts rms... but can handle more.
Glidden, Iowa U.S.
Post Number: 84
i like the sx but i dont know if my alternator could handle a 1000 watts rms amp. And i dont want to upgrade that thats too expensive. What do you guys think?
Username: Robert_d
MIA, FL USA
Post Number: 216
you could get 4 RE's and push them 175 rms each which is 700 rms i dont know any 700 rms amps but good companies underrate there amps like kicker will probily hit 700 rms with there 600.1
put them all in a ported box
that should get pretty loud
the coule kids i know that are pushing more than 500 rms with there stock alternator dont seem to have a problem but that requires alot on your car i have a 93 camry but it handles it fine
thats just my 2 cents maybe someone who knows more probily has a better idea
Glidden, Iowa U.S.
Post Number: 85
I think 4 res is too much and would take up to much room maybe 3 with a 600 watt amp. And how would a 15 se compare to 2 or 3 12 inch res and to 1 12 inch sx
Username: Robert_d
MIA, FL USA
Post Number: 219
well i dont really use my trunk so thats me but well the SE are SQ subs
they said the eclipse ti are really head to head with the SX and they only need 750 rms
Glidden, Iowa U.S.
Post Number: 88
So 1 sx 12 would be alot louder than 2 re 12s?
Username: Rovin
Trinidad & T...
Post Number: 1306
this is the power rating of RE's subs
RE - 175wRMS -- DVC 4 ohm
SE - 600wRMS -- DVC 4 ohm
SX - 1000wRMS -- DVC 2 ohm
XXX - 1600wRMS -- DVC 2 ohm, QVC 2 & 1 available
MT - 2500wRMS to 5000wRMS -- DVC .7 & 1.4 ohm, QVC .7 & 1.4 ohm
so ya ! - 1 sx would murder 2 RE subs - lol
Glidden, Iowa U.S.
Post Number: 93
what would be a good amp for the sx thats 1000 watts rms at 1 ohm for about 300 dollars?
Username: Iufan4lifeul
Post Number: 544
I will give you some first hand experience on the RE's. I am one of those high school kids who like loud... BUT I also like SQ with it being loud. Being short of money and all I decided with the Kicker 450.2(225rmsX2) and 2 RE12's SEALED. Ported would be louder but they are plenty loud for me and sound AWESOME. They are punchy beyond belief. I really can't even describe it, never heard a sub that hit you in the chest so hard, accurate etc. Great for all types of music (can get REALLY low too). I had trouble with the install at first but after a simple fix everything is going good now. If you have any more questions about the RE's just let me know, I will try to help.
Glidden, Iowa U.S.
Post Number: 94
wow sounds just like me lol. Im trying to elarn as much as possible so i dont go waste 500 busk on subs and an amp i wont like.
Username: Rovin
Trinidad & T...
Post Number: 1313
u'd be hard pressed to find a good amp brand online unless u go ebay .
hmmmmm - i could sell u my new still in box never used MB quart raa1000 which i paid $300 @ crutchfield , could let it go for same price + s/h cause i'm thinking 2 750 wrms subs 4 myself.....
Glidden, Iowa U.S.
Post Number: 95
i think 1000 watts rms is too much and too expensive.
Hey chris so you think they will be loud enough in a sealed boxor go ported?
Username: Rovin
Trinidad & T...
Post Number: 1316
looks like he's gone .
what about if u got a single 12" SE $169 & a Hifonic amp as it seems like u are on a budget .....
Post Number: 545
hondarider, if you want the "punchiness" go sealed. It is plenty loud.
