Quick question about sealed enclosure and my subs
Username: Stevehume
Post Number: 11
hi,
I have 2 10"Infinity 1030w, recommended for sealed enclosures 0.75 cu/feet ... now i have a box that is 1.5 cu/feet is that ok for 2 of these subs? since im guessing they require 0.75 each?
Thanks
Steve
Username: Carguy
Post Number: 4719
Yea, that's okay in volume wise.
Username: Thigpen
RVA, Va Usa
Post Number: 147
im about to make a box for 2 10" RE SE's, do you just double the box volume for a single sub or is there more to it for the best sound possible
Username: Carguy
Post Number: 4720
It's best to give each sub, it's own space. If you share, you'll have cancellation problem.
Username: Thigpen
RVA, Va Usa
Post Number: 148
what do you mean, i see boxes all the time that are built for 2 subs... and i dont have the trunk room for 2 single enclosures in a 3000Gt...wouldnt you just double the required room for a single sub to get the cu.ft for 2 subs?
Username: Killerzracing71
Fredericksbutg, Virginia United states
Post Number: 96
build a wall to seperate the two subs in one enclousure
Username: Redskin
LondonEngland
Post Number: 184
"It's best to give each sub, it's own space. If you share, you'll have cancellation problem"
Please explain why you'd have a cacellation problem.
Username: Eddyg519
Post Number: 9
yeah my friend has 5 12" infinitys in his car, all in one box..
