LANZARS FINNALY AT 2OHM
Username: Caraudio
Toronto, Ontario Canada
Post Number: 210
OH MAN MY TRUNK WONT STOP RATTLEING PAST 23/40 how do i get rid of the rattle:S? Dynamat and what ever best place to buy it please?
Username: Caraudio
Post Number: 211
USING MY VIBE 248 at 2ohms pushing 500RMS WOOOW
sucks to be you....
Username: Caraudio
Post Number: 213
How do i stop that rattleing:S???
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=12657
SOmthing like that for my Civic TRUNK ANY ONE PLEASE and THANK YOU!
Username: Kd7nfr
Montpelier, ID United States
Post Number: 1026
Dynamat it.
Username: Caraudio
Post Number: 217
LInk to a great online buy plz?
Username: Corey
Post Number: 25
I have the perfect site. (www.google.com) eDead it
Username: Caraudio
Post Number: 224
thanks for the name its actually google.ca around here but thanks mr.genius.
Hate it when people act smarter then they are i ask for a link to a STORE for a great buy and u gave me a name and google thanks:S
If any one else knows or has bought from some where b4 that was a great buy plz let me know thanks.
Username: Basshead86
Ocala, FL USA
Post Number: 2139
the cheapest place to buy dynamat is on ebay.
and for the most for you money, buy the bulk pack.
Username: Caraudio
Post Number: 227
20sq foot? or 40sq foot? How much would i need for my civic trunk and do i gota put it on the trunk door or all around in trunk would be best?
Username: Caraudio
Post Number: 228
also now would you reccomend a bigger battery? or a capacitor because the lights start to dim alot.
Username: Corey
Post Number: 26
I say edead would be a cheaper alternative to dynamat http://edesignaudio.com/category.php?type=damp
but if you want to use dynamat, you would cover the entire trunk with it. Sorry about that other post, I was a little irritated about something.
Ocala, FL USA
Post Number: 2141
put it in both places.
to solve this problem, you will need a HO Alternator and a new battery.
Username: Caraudio
Post Number: 229
alright the HOLE TRUNK? I only have rattle from the trunk door tho.
Username: Caraudio
Post Number: 230
Well i guess for now ill go with a bigger battery 1000RMS isnt big enough load to demand a bigger alternator isit? Would it screw it up for the long run?
Username: Caraudio
Post Number: 231
Muddy is this okay bro??http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26%26item%3D5775421195&ssPageName= STRK:MEWA:IT
Username: Corey
Post Number: 29
If your lights are severly diming, you WILL NEED a HO alternator esp. with a 1kw amp.
Username: Caraudio
Post Number: 232
its just minor the inside light dims just a tad on a hard hit base note only when the car is at a stand still. Plus at night time it wont be playing this hard no way i dont want to draw to much attention.
Ocala, FL USA
Post Number: 2144
i had a 300wRMS amp in my car and my lights dimmed. lol
so i got an HO alt........problem solved.
now i have TONS of headroom for upgrades in the future.(some of which i have already done):-)
btw, your link isn't working for me.
Username: Caraudio
Post Number: 233
ebay links never work bro ima try it aagain.
http://cgi.ebay.com/40Sq-Ft-eDead-Sound-Deadening-67-Off-Retail_W0QQitemZ5775421 195QQcategoryZ67760QQssPageNameZWD1VQQrdZ1QQcmdZViewItem
if that doesnt work www.ebay.com
search edead and scroll down to the buy now section at 35$ 40sq.
Username: Caraudio
Post Number: 234
dont think i want to spend money on a HO if lights dim slightley maybe bigger battery for winter start ups and thats about it unless HO going to damanage anything else
Ocala, FL USA
Post Number: 2147
i have heard Edead works really good, but some people complain of its smell and lack of "stickiness"
but i would definitely go for it. it will dramatically reduce the vibrations.
Username: Caraudio
Post Number: 238
the one from the link???????
Username: Thigpen
RVA, Va Usa
Post Number: 137
im looking at some HO alternators for when i put my 2 SE's and componets which i havent determined yet in my car, how big of an alternator will i need, and how much will it cost. i talked to another guy who put a 200amp alternator i believe in his 3000Gt like mine and said it cost him 600$.. do i need one that big and will it cost me that much?
Username: Caraudio
Post Number: 239
http://cgi.ebay.com/40Sq-FteDeadSoundDeadening67-OffRetail_W0QQitemZ5775421195QQ categoryZ67760QQssPageNameZWD1VQQrdZ1QQcmdZViewItem
Ocala, FL USA
Post Number: 2160
yeah, that should be more than enough.:-)
Username: Caraudio
Post Number: 240
nICE nicee well ill get that then thanks bro. Now how id get that installad and stuff would be somfing id want to know how to do would i need to tape the ends just to make shore or what?
Ocala, FL USA
Post Number: 2167
they should provide you with a roller tool, which gives it a nice "grab" to the surface you are applying it to.
Username: Caraudio
Post Number: 241
shuld i take a picture or somfin and show u what im going to have to attach it 2 for u to get a better feel of what im doing n if it iwll work :S? or it will work regardless?
Username: Caraudio
Post Number: 242
Oh and on my HU i turned the base down from +12 too +2 because that was gettting hectic ill prolly turn it back up after i get the dynamat but i dont wana over do it what so ever will the band pass box hurt my subs in any way:S?
