Is this enclosure good for re sx or other subs ?
Username: Sinx85
Post Number: 31
hey guys can any one please tell me if this enclosure is good
http://www.bestbuy.ca/catalog/proddetail.asp?logon=&langid=EN&sku_id=0926INGFS10 036482&catid=20121#
thankx
Username: Sinx85
Post Number: 34
guys can any one plz tell me if this is good or bad?
Username: Quickshot
Charlotte, North Carolina U.S.
Post Number: 296
no prefab boxes are almsot never good especially for a higher end sub like an SX which requires huge boxes...never buy a prefab always make your own accordin to factory specs or have one made for you
Username: Dementedvisions
Cedartown, GA
yeah bro why waste 150 bucks when you can make a custom one for far far less and make it look better just go buy some MDF board 3/4 inch some screws,wood,glue,liquid nails draw out and measure your space then get to work...
Demented Visions
Username: Sinx85
Post Number: 35
thankx for replying :-)
well i guess i gota make my own then
where can i buy MDF board ? and whats MDF?
also can any one list like what type of nails, glue and stuff i should use and where to buy them from. I live in mississauga, canada.
also this box will be for 2 re sx 10"
once ihave all the supplies, how will i cut the round circles to fit 10 inc ? and how will i vent it?
should i make seal box or vented?
you guys know any site or link where they show you all the steps :D
thankx
Cedartown, GA
Post Number: 8
well first you can buy MDF board at like lowes or home depot I would use 3/4 inch its sturdy and strong also your list should have
1 inch wood screws
wood glue
liquid nails " this is for sealing up your edges"
circuliar saw for straight cuts
Jig saw this is for your circles
you can find step buy step instructions just look on the internet under
building a subwoofer enclosure
Demented Visions
Username: Sinx85
Post Number: 36
thankx
Username: Sinx85
Post Number: 37
mmmm sorry for the double post.
thankx demented :-)
Cedartown, GA
Post Number: 11
no problem
