Alternator wire
What kind of wire should you use to upgrade the wire running from the alt to the battery?
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 1012
use at least 4ga.
1/0 would be better.
just regular power wire though? same stuff you run from the battery to the amp?
Username: Glasswolf
Wisteria, Lane USA
Post Number: 10386
yes, the 'big three' are done with the same wire used to run from battery to amplifiers.
you'll want to replace engine to chassis ground, alternator to battery positive line, and battery negative post to chassis ground using this larger wire, for a solid circuit upgrade.
