I need suggestions on an amp for...
Username: Sandmanz400
Reserve, N.M. U.S.
Post Number: 13
i need a suggestions on what amp i sould get for my two 10"s W7 subs.
and my friend needs suggestions on an amp for his two 10"s r-types?
help us pleaze!!!!!!!!!!!!!!!
Robert J
as you probably know it is hard to find a 3ohm amp, so i would stick with the jl amps and go for there 300/2. But i'm not sure of the rms on your 10w7s so as long as the rms isn't over 500, then that is the amp for you. now for your friend seeings how he has alpine it looks like he want's high quality, and i'm the same way. so for him i would go with the Alpine MRD-M501, now they coast $500 on crutchfield, but you can get them for less else where. Now if you guy need some cheaper alternatives just say so and i'll see what i can come up with.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 1671
JL 500/1 for the 10W7s
Kicker KX600.1 for a pair of 4 Ohm Type-R subs
Reserve, N.M. U.S.
Post Number: 18
robert J i told my friend bout the amp in crutch, he thanks u.
see i don't really have the w7's yet but im getting them this summer and plus im getting a real good paying job this summer.
so if you will plz see what you can come up with on both, an amp and some w7 10's. ty
