Underpower
JKL
My subs are rated at 700 RMS, but I have my amp hooked up at 4 ohms, so the subs are only getting around 200 RMS. How bad is this for the subwoofers?
Username: Geekbike
Post Number: 370
OH GOD NOOOOOOOOOOOOOOOOOOOO!!!!!!!!!!
There will be absolutely no damage unless you crank your gains up and start clipping them.
Username: Mikechec9
Chicago/atlanta
Post Number: 814
which would be all but inevitable in my case.
it's going to be really easy to do with that much discrepency.
all my blown subs (in my early day) have come by way of underpowering and playing aggressively. just me though.
so like knacko said, be aware and cautious until you get a new amp and you should be fine.
