Head unit power
Travis Larocque
The head unit is not even coming on when I hooked it up i am new to car stereo and need a bit of help. There is the ground wire not coming from the fuse box that i cannot find where it is to go? all i need is to get the head unit on then i can get the rest. If it makes any help it is a (Innovatek 391MP3)
Thanks for any help.
Travis
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 775
If you don't know what you're doing, get it done professionally.
