Need subs for my PPI A600.2 Art Series
Username: Sarahaz
Yuma, AZ
Hello everyone, I'm new. I have an old PPI A600.2 (the white one)and i would like to know what subs would be appropriate to buy. Any feedback will be appreciated. Thanx.
Username: Tbolt
Collipark, GA United State...
Post Number: 574
whats your price range?
Are you looking for sound quality, loudness, or a mixture of both?
Username: Sarahaz
Yuma, AZ
about $150-$200ea.
I basically wan't to be heard from far away(blocks if possible):-)
I guess a mixture of both?
I wan't to make sure the amp doesn't overheat and shut off on me.
Username: James1115
Wilton, Ct
Post Number: 3871
anything that is 600 rms at 4ohms will be perfect. that amp can only be run at 4ohms mono so dont try to drive it at lower impedence's. That is one of the best amps ever made dont risk blowing it up. Get a dual 2ohm sub and hook it up in series/parelell at 4ohms and you will be ready to rock. I have a ppi a600 and have run multiple sub set-ups off it and it is a fantastic amp:-) much better for mids and highs but great for the right VC config's in subs also.
Username: Basshead86
Ocala, FL USA
Post Number: 133
don't less Glass read that you want to be heard from blocks away..lol
Username: Dominirica012
Charlotte, North Carolina US
Post Number: 715
its going be a little hard to find 2 subs that get really loud with only 300rms per sub...have you considered 1 sub like a 15" Alpine Type R or a 15" Eclipse Aluminum
Post Number: 716
whoops i dont think that Eclipse makes a 15" AL but you know what i mean..maybe even a TI although your underpowering it a little bit
Username: Ffxdevilarms
Dubuque, Iowa United States
Post Number: 979
how about 1 15" SE from RE.
Post Number: 720
thats also a good choice which i was thinking about but i hear that those subs dont get too loud their mostly SQ but im not 100% on that
Post Number: 983
i am not sure my self. The RE series are very SQ oriented, but with four of them i get all the SPL i need. Those SE's should be nice though.
Username: Mikechec9
Chicago/atlanta
Post Number: 685
for two subs i would consider the JL w3 or the IDQ.
if you do one sub-the new brahma or rl-p. they sound good with 600-750 watts.
Username: Mikechec9
Chicago/atlanta
Post Number: 686
and nice amp. truly a performing collecor's item.
Post Number: 990
get some RE 12's. They are really nice for the price, and you should be able to get different VC config it needed. Can you fit 4 of them in your vehicle???
Post Number: 730
i dont think he wants 4 since those SEs are 600rms a piece and his amp is only 600rms so hell only be able to power one
Post Number: 1020
no, i was talking about RE12's like me.
Post Number: 736
o my bad yea that would work
Post Number: 1038
I love my 4 RE's, and for the price they are a great buy, so i figured i would suggest them.
Username: Sarahaz
Yuma, AZ
I appreciate the feedback guys:-)
There are only about 3 shops it my city and a Best Buy... the shops are authorized dealers for Crossfire, Eclipse, JL, Kicker, Fosgate, & Alpine. Those are pretty much my options unless I order from the internet but I'm conserned about warranty and my budget (that's the reason I'm using this amp that's just been collecting dust). The only sub I have heard so far is the Crossfire... one of the guys at the shop hooked up one 15" real quick so I can listen to it and I was pretty impressed... I would like to compare it to others, maybe 2 Eclipse 10"?
Anyone familiar with Crossfire? pros & cons.
I just got a Mazda3s 05' 4-door not hatchback and the trunk is quite roomy. Don't know the exact measurements.
