8" Amplified Subwoofer Tube System
Username: Ward
Chevy Chase, Maryland
Post Number: 7
is it any good. not lookin for a super loud sub but some decent sq
Username: Subzer0
Richmond, KY USA
Post Number: 598
the tube effect is so they will be loud, they won't loud but will be loud.. I dunno about sq, I suppose it'd be nicer than some things though.. if you have a good deal on whatever it is.. it's worth a try to get a single one.
Username: Subzer0
Richmond, KY USA
Post Number: 599
the tube effect is so they will be loud, they won't pound like bass does but will be loud.. I dunno about sq, I suppose it'd be nicer than some things though.. if you have a good deal on whatever it is.. it's worth a try to get a single one.
Username: Tbolt
Collipark, GA
Post Number: 443
"they won't loud but will be loud" lol
Username: Subzer0
Richmond, KY USA
Post Number: 602
.. i corrected it.. :-) fool.
Username: Tbolt
Collipark, GA
Post Number: 447
*more lol*
Username: Ffxdevilarms
Dubuque, Iowa United States
Post Number: 960
Just go with an 8" sub that need a small enclosure like an RE8.
