Difference between 1ohm,2ohm,4ohm loads?
need some help
you guys prolly answered this question a million times..but...
whats the whole deal with the different loads?
how does it effect power?
am i being 2 general?
Username: Ffxdevilarms
Dubuque, Iowa United States
Post Number: 1186
The ohms of the voice coils on the subs affect what kind of a load you can use on your amp. If you have 2 dual 2 ohm subs you can wire in a .5, 2, or 8 ohm load. If you wire 2 dual 4 ohms subs you can wire in a 1 or 4 ohm load.
You can get many different wiring diagrams on the net that will help you out with what ohms you need to get for you sub and amp combo.
Username: Tbolt
Collipark, GA United State...
Post Number: 669
for every half of an ohm load, you double or half the power. ex. 4ohms 100 watts, 2ohms 200 watts, 1ohm 400 watts.
Username: Dominirica012
Charlotte, North Carolina US
Post Number: 785
thats not always the case...in theory that is true but in real life sometimes the power doesnt dbl as the ohm load decreases but usually it tends to
Post Number: 1191
Ice, you should post in white. lol.
Username: Tbolt
Post Number: 671
ok
Post Number: 787
wtf i can barely see that..post in like a greyish font with the gray background
Post Number: 1197
dam, do it when it is a white background so i dont have to see what you type.
need some help
ok..
another quick question...why if you bridge a 2 channel amp together..it sees ((as an ex.)) a 4ohm sub as a 2ohm ?
and is using a 1 ohm better or worse then a 4ohm?...why?
do any of the loads hurt the subs?...do any sound better or are they just different ways to get power out of your amps?
any preference?
Username: Tbolt
Post Number: 675
fu(k you b!tch
Username: Tbolt
Post Number: 676
not you guest lol
Post Number: 793
when you bridge a sub it doesnt see a 4ohm sub as a 2ohm..it sees it as the 4ohm sub it is...ohm load does not afect the performance or life of a subwoofer, all it is is just a way to get power from your amp
need some help
as an example...im thinking of getting...
2 12" Type-R Subwoofers (4ohm + 4ohm)(dual voice coil)
what amps should i use?...a mono for each maybe?...one 2 channel?...and wut wiring for max/best power
this is my last question...i swear..haha
Username: Tbolt
Post Number: 684
A mono, 1ohm stable amp. Wire the subs in parallel
need some help
i had my fingers crossed !
the subs are 500 watts RMS each...
parallel wiring would obviously make it 1000 watts RMS...correct??
so i would need a mono amp with 1000 watts RMS?
Username: Tbolt
Post Number: 686
no, my first posts was talking about the amp not the sub. Parallel wiring makes the subs have a 1ohm load for the amp to push. you still need to get a 1000 watt amp though since both subs are 500w rms.
need some help
dont take this as arrogant...cuz your the one schooling me in all this...
but isnt that wut i said?
i said...
"so i would need a mono amp with 1000 watts RMS?"
thats right^...right?
if so...
which would you buy...
Kenwood KAC-X811D
or
Hifonics Brutus BX1000D
or would you buy something else?...any suggestions?
need some help
its not showin i posted again...
just tryin to get ice man 2 see my question
need some help
