How to wire head unit
Ok I have a 1969 Cadillac
The guy who sold it to me left some makeshift box in it with a Pioneer head unit and four pioneer speakers in it. It was not wired up but wires were running here and there.
I have a black wire (ground I assume) a red wire that says to connect it to the ignition source
and an orange wire that says to connect it to a constant power source.
What is the best way to do this
any suggestions please
Oh and this is a Hearse so dont ask for a body style its defined by coachbuilder
the engine and the main wiring harness is about the only thing stock GM
Thanks
GET A WIRE HARNES IT WILL WALK YOU RIGHT THROU
Sean Blanck
That doesnt help the answer I'm looking for is
where would you put the constant power wire
I'm thinking of running it straight to the positive side of the battery witrh an inline fuse
Sean
yes hook it up to the battery with an in line fuse.........that is the best way
I NEED TO KNOW THE WIRING CODE FOR A 1999
NISSAN ALTIMA, I'M TRYING TO PUT IN A CD PLAYER
WITH OUT THE HARNEST
try here for wireing codes
http://www.installdr.com
im trying to put a cd player in my altima but the person who had it b4 me cut the wireing harnis out and i dont know what wires are which how can i find out what each color is?
hey any one want a 86 ford tempo 2.3 lt $800 only has 78,000 origanal miles.call me or email me at cnassetta86@hotmail.com or 207-671-6502
