Using Navigation screen to play movies
Username: Fordpwr
Los angeles, CA Usa
Post Number: 310
I have a Factory navigation unit in my SUV, My question is, does anyone know where to get that especial adaptor or what have you, to use my navigation monitor as a dvd monior.
Username: Fordpwr
Los angeles, CA Usa
Post Number: 312
Username: Clethal70
Post Number: 11
What are you trying to do again? Are you trying to used that monitor in your Suv as a dvd monitor to play movies? and if so i would ask the dealer about that to see what model that would attach to that unit.Sound like a factory job or something you might have to do alot of reseach on.
Username: Fordpwr
Los angeles, CA Usa
Post Number: 316
My ride has a factory dvd player w/monitor combo in the rear and I also have a factory moniotr in the front but thats only for the navigation unit. I also bought aa seperate dvd player that I'm using the rear moniotr with because stock unit wont play burned dvd's.( this one has A/V conection wich is why I was able to hook it up to the new dvd player) I'm trying to hook up the front monitor to my dvd player, However because it a nav. moniotr you have to get a special adptor. I hope it makes sense
killerzracing
NAV-TV CAll them up and you be set
