Wiring 6x9s to headunit
Username: Marco_v
i have no rear speakers so i am wanting to install 6x9s on the rear shelf. only problem is, i dont know were to wire them into the headunit! i dont want to use an amp so i need to run them off the headunit. i used the factory wire for the front speakers so it was easy but as there is no rear speakers i cant do this for the 6x9s! also, wot sort of wire should i be using for the 6x9s? please help!
Username: Riebread77
Post Number: 328
you can't just tap into it because it will change the impedance. You'll have to use the factory wire...if it is run to a different place, just connect your own and run it to where you want it.
Username: Marco_v
alrite man thanks for your help ill give that a go!
