K guy's, on the hunt again... need yalls help.
Username: Taylor17
Kopperl, Texas
Post Number: 2644
Looking for 1 sub, needs to be wired to 4 ohms, and has to be able to handle 800 watts rms, and needs to be cheap. Sq isn't needed, just spl. I know audiobahn would be a good choice, but its even hard to find a sub that meats all of these requirments. Most audiobahns that will work, are rong ohms. If anyone can help... it would be apretiated.
Oh, did I mintion has to be cheap? lol
Username: 54danny54
Post Number: 728
lol why u want one like that?
Username: 54danny54
Post Number: 729
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=2678
if u consider it cheap...these get very loud
Username: Taylor17
Kopperl, Texas
Post Number: 2648
Like what?
Username: Taylor17
Kopperl, Texas
Post Number: 2649
Lol, I didn't even know Lightning audio made a sub that cost that much... and needs to be cheaper. Way cheaper... under $100 would be nice, hints Audiobahn.
Username: 54danny54
Post Number: 731
lol kk...give meantoher second.
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=2761
u can safelyt give it 800 watts, my friend is
Username: Taylor17
Kopperl, Texas
Post Number: 2650
AWE, see, its 4 ohm dvc... can't be wired to 4 ohms.
Username: Taylor17
Kopperl, Texas
Post Number: 2651
I've found lots of subs that have the right rms, and price, but there all 4 ohm dvc! Does anyone make a 2 ohm dvc any more? lol haha
Username: Carguy
Post Number: 3684
Taylor17, have a look at SoundSplinter RL-P12.
Username: Taylor17
Kopperl, Texas
Post Number: 2652
Where can I find them? sonicelectronix.com and woofersetc.com doesn't have them.
Username: Subfanatic
Ky
Post Number: 4582
taylor, what about an avalanch, they are dvc 2 ohms
Username: Dominirica012
Charlotte, North Carolina US
Post Number: 577
no SQ needed? "im looking at a magical square that sounds like @$$"
Username: Taylor17
Kopperl, Texas
Post Number: 2653
Lol Quick Shot, I'd love to find one of them "square subs", but most are too expencive, and Sub, the Avalanch's are to expencive too.
Username: Carguy
Post Number: 3686
Taylor17, do a search on google and you'll find them. It's priced around $215-$250. It just might do the trick for you. It won't fetch a stick though.
Username: Taylor17
Kopperl, Texas
Post Number: 2654
Damn! Too expencive. I'm just looking for a cheap spl sub. They look sweet though!
Username: Jaackdeth
United States
Post Number: 260
Have (2)PPI Precision Power DCX 12 Subs Dual 4ohm $150+ship
Username: Glasswolf
Wisteria, Lane USA
Post Number: 8462
Kicker S15L7
look on ebay for a used one.
The S12L7 will do the trick as well.
go slot-ported, and tune the 12" to about 35Hz, or the 15" to about 28Hz.
you'll get tons of SPL.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 8463
PS, one sub, 4 ohm load, get the dual 2 ohm coil model sub.
Username: Taylor17
Kopperl, Texas
Post Number: 2657
Thats what I had in mind, but I was just seeing if anyone else had a better choice.
Slot ported, you have to go and make things difficult.:-) Just building a regular ported box is going to be hard enough!
Username: Hurleyblink
Post Number: 68
just get a audiobahn flame compression 12... you can get it on ebay for $92 plenty of spl if you can spend a little more get the 15
Username: Iowahawks19
Post Number: 317
go with a solobaric kicker like glass recommended, used they go for dirt cheap on ebay, but i don't know how long it will last you
those L7's get crazy loud for the price though
Username: Taylor17
Kopperl, Texas
Post Number: 2664
Lol yeah, thats really my only worry.
It won't be used everyday though, more to show off to friends, if I get the results I think I will.:-)
Username: Carguy
Post Number: 3690
You trying to get lucky with those subs? Just kidding.
Username: Taylor17
Kopperl, Texas
Post Number: 2667
Lol... you bet you're sweet a@ss. hahaha
