Hey glass, alpine 9183 or 9185
Username: 350_blaze
Post Number: 24
Do you know what are the major differences between the two. I can get a 9813 for $200 it was a display in a glass case never used, Should I go for it?Box and warranties, every thing applies with the 9813.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 1590
did you mean 9813 or 9815?
if so the 9813 for $200 is a good price. good unit.
the 9815 added a blue two-line display, and iPersonalize for pre-setting sound environments with things like time correction etc. mostly nothing vital or all that important unless you're really picky about fine tuning a system with a meter. both are good units.
Username: 350_blaze
Post Number: 26
Thank's I'll go with the 9813.
