Dual voice coil
Username: Dominirica012
Charlotte, North Carolina US
Post Number: 78
If a sub has dual voice coils can you power it with 2 different amps?
Post Number: 81
bump
Username: Alpineuser
Winchester, TN
Post Number: 592
you can power it with 2 amps but the amps should be the same type of amp.
Winchester, TN
Post Number: 593
assuming it can handle the power.
Post Number: 82
what if one amp is 360 watts and the other one is 400...will that uneven distribution damage the sub?
Post Number: 89
bump...why doesnt anyone ever answer my posts
Username: Kicker
Slave lake, Alberta Canada
how do you hook up 4 cvr12" kicker dual voice coil sub to one 2 channel amp 850.2 kicker staying at 2ohms
Username: Shadylimitedx
Pgh, Pa Usa
Post Number: 231
heres dual 4ohms coil http://www.rockfordfosgate.com/rftech/wiringwizard.asp?WoofQty=4+woofers&WoofImp =Dual+Voice+Coil+-+4+ohms+x+2&image.x=17&image.y=7 an heres dual 2ohm coils cant get a 2ohm load wit dual 2 ohms
Username: Illuminator
Post Number: 698
"what if one amp is 360 watts and the other one is 400...will that uneven distribution damage the sub?"
It most likely will cause damage, I wouldn't use the two amps due to the fact that so many things could go wrong and end up ruining the sub. And if you're running in stereo, then you'll definitely ruin it.
