Anything better then Memphis??
Username: Needstheeraser
Murfreesboro, TN USA
Post Number: 12
I'm looking for new 4" speakers to put in my front doors of my 91 Honda Accord, I was told to get Memphis M-class being that they aren't too deep and produce great sounds. Is there anything better out there that isn't too deep that i can put in my front door or is Memphis the way to go. I'd appreciate all the help I can get. Thx.
Username: Geekbike
Post Number: 198
4x6", 4x10" or 4" round?
Post Number: 13
4" round
Username: Carguy
Post Number: 3367
Infinity makes 4" component speakers. Sounds great.
Post Number: 14
well i couldn't find the component but i have infinity kappa 693.7i in my rear deck and they sound awesome and i was going to go with the Infinity Kappa 42.7i for my front doors till i went to a local audio store and they suggested the memphis m-class but what would guys choice? thx, my only worry is depth
