Got my new system installed today...what do u think??
Username: Masse1369
Post Number: 52
Item Description Price
Head Unit: Alpine DVI-9990 $2,400.00
Signal Processor: Alpine PXI-H990 $4,000.00
Front Stage: Scan-Speak 18W/4531G 7" Midbass $448.00
Scan-Speak 12M/4631G 4.5" Midrange $440.00
Scan-Speak R2904/7000 Tweeter $900.00
Amplifiers (FS): (3) Sinfoni 60.1 $8,250.00
Interconnects (FS): (3) Kimber Kable Select KS 1030 - 6.0M $20,640.00
Speaker Wire (FS): (3) Kimber Kable Select KS 3038 6.1M $56,400.00
Rear Fill: Scan-Speak 18W/4531G 7" Midbass $448.00
Amplifier (RF): Sinfoni 60.1 $2,750.00
Interconnects (RF): Kimber Kable Select KS 1030 - 6.0M $6,880.00
Speaker Wire (FS): Kimber Kable Select KS 3038 6.1M $18,800.00
Subwoofer: (2) Alto Mobile Falstaff 12 $1,900.00
Amplifier (SUB): Sinfoni 150.2X $1,490.00
Interconnects (SUB): Kimber Kable Select KS 1030 - 6.0M $6,880.00
Speaker Wire (SUB): Kimber Kable Select KS 3038 6.1M $18,800.00
Sound Deadening: Second Skin Damplifier Pro (180 sq ft) $1,250.00
Sales Tax: $10,687.32
Grand Total: $163,363.32
Sorry I was a little bored earlier:-)
Username: Dozyproductions
San Diego, California United States
Post Number: 43
wow...whos the thug you stole the money from?
Username: Illuminator
Post Number: 650
So this is a dream system...?
18,000 for speaker cable? It's probably pure silver or gold, but honestly. That isn't crazy, it's stupid.
Username: Masse1369
Post Number: 53
silver actually, and its completely worth it, it sounds pretty good, lol. actually i went with:
pioneer premier p860mp
dynaudio system 360
treo tsx15.44
tru t03-4.150 (sq modified with upgraded power supply and kimber kable)
ixos cables and wiring
second skin sound deadening
should have it all installed within a 30 days or so.
Post Number: 657
You're insane! You pay more for the wiring than the components?!
Username: Geekbike
Post Number: 199
The difference between $20k cable and $30 cable is about 0.02THD. It's stupid, as road noise would easily cover up any benefits.
Post Number: 658
Exactly!
Post Number: 48
let me say this. if you think youll be driving around just showing off how much better your system is, then you got to think... people payed a thousanth than what you paid and they are still enjoying their systems. plus your car is going to get hit by the lug of nuts i drive, id like to see those golden tears.
Username: Masse1369
Post Number: 57
you people amaze me it was a joke, i spent about $4000 for everything, including the install for dyns and bad boy tru.
Post Number: 49
meh, needed to relieve some stress. and thinking of hitting your car was the best route.
Username: Carguy
Post Number: 3371
Ha ha, that was funny.
Username: Alexochoa
Tucson, Arizona USA
Post Number: 50
Do you really think, someone would be that stupid spending 18,000 on wires?
Post Number: 65
yes nothing is impossible
JoJo193
I got a full Alphasonik 800 series system, HC 4-channel, and D class mono block sub amp that would f&ck your system hard. I paid dealer cost and it all ended up under $3000. What a dumb f&ck. 5 farad mobilespec and a HO alternator. Spend your money wisely, and dont go for the mainstream f*ck off brands. Find REAL speakers.
Username: Ssoonr
Dallas, Texas
Post Number: 52
Ryan- keep dreaming, although your dyns should sound awesome, let us know how they do. That tru amp is definately a bad boy (sq upgrade = Burr Brown upgrade?).
