Which is a better system?
Username: Thrushdtd
New York
Post Number: 87
I have two 12" alpine type r's 500rms a peice in a seald box with a jbl 600.1 powering the two and my freind has a kicker 600.1 powering two kicker 12" l7. which is better?
Username: Taylor17
Kopperl, Texas
Post Number: 2168
Well, I'm guessing you're friend's is louder, but over all, I'd go with the 2 type R's... you might look in to getting a bigger amp though.
truth1
well the kickers are way undered powered but who ever is first to get a 1000 watts will rule.
Username: Thrushdtd
New York
Post Number: 99
i just got a 1250 rms us acoustics amp so well see how that works out
truth1
put the kicker in the bigest ported box you can get u will crush him
Username: Thrushdtd
New York
Post Number: 100
yo i have the alpine type r's
truth1
oh sorry sell them get kickers
Username: Subzer0
Richmond, KY USA
Post Number: 151
.. umm maybe he doesn't want pure spl? keep the type r's... they are good.
truth1
now if i just have the volume up a little then sq can be a factor or in your home now when you want to bump lill jhon and running 2000 watt of power sq???? where in your mind? what kind of sq can you hear at 150 db? please let me know?
Username: Subzer0
Richmond, KY USA
Post Number: 152
I don't recall wanyone wanting sq at 150dbs.. kindly clarify wtf that has to do with anything?.. loudness doesn't have to mean .. how much ground you can shake.
Username: Fordpwr
Los angeles, CA Usa
Post Number: 267
truth1
you are rite and i was wrong, i assumed he ment that he wanted to know who was better, and when one makes that statement one is led to belive he want his system louder then his frinds, i may be wrong he could just want his to sound better sq wise, he did not say what he ment by better.
Username: Thrushdtd
New York
Post Number: 103
well i do enjoy sq but wont mine be louder too because i have the bigger amp even though he has the louder kickers? plus im putting mine in a ported box.
Username: Subzer0
Richmond, KY USA
Post Number: 155
if ported those type r's will be loud.. and clear.. they should carry over those kickers.. which are made for spl.. they will shake.. yours will be heard more ;).
Username: Thrushdtd
New York
Post Number: 105
nice
Username: Hdubb
Farmington, Nm Usa
Post Number: 1843
Username: Subzer0
Richmond, KY USA
Post Number: 156
?.. i'm confused with all the sad faces and nice comments.. :/
