Need to know how to take door panel off for speaker installation
Username: Justababyboy
Can someone give me any incite on how to take off the door panel of a 2001 Buick LeSabre Limited. I have tried the basic steps of any other car but the damn thing will not come off, PLEASE HELP
THANKS
I just did a Buick Park Ave, can't be too different from LeSabre. On the door, there should be an armrest with a small well, about long enough where you can put pencils and whatever. There should be a small, long thin panel with a small square hole. Squeeze this panel from the ends and it should pop out revealing 2 screws. Remove those.
Next, open the door, and in the door jam, there is a small round black cubby hole with a plastic screw inside. Remove the plastic screw.
Finally, remove the plastic molding around the door handle. You should see the outline of this molding around the door handle, if it's on the LeSabre.
Now all you have to do is push/pull UP on the door panel and it should pop right off. Just remember to PULL UP and not out or you'll break something.
