Installing two amps
p43.2E
My friend has a four channel amp right now hooked up to two 12"s ... we are gonna also put in my jl 12w3 and 250/1 mono amp ... how do we run this...?? thanks
xdrummer03
Get a dual Amp Kit. Usually one 4 ga into 2 8ga wires so you have 2 power wires. Then run 2 grounds from amps.
p43.2E
what about remote? and do i connect the rcas to my jl amp and use preamp output to connect it to his amp? thanks for the reply
Username: Bob_falfa
NE
Post Number: 14
Perhaps this will help:
http://www.crutchfieldadvisor.com/S-AKt4sCcQnpF/learningcenter/car/amplifiers_wi ring.html
p43.2E
still dont know what to do with the remote wires ?? maybe im lookin at it wrong ?
p43.2E
Splce it or run two maybe
