HELP PLEASE!!!
Username: Balls573
Winona, Missouri U.S
Post Number: 75
i hooked my friends cd player up in her cavalier and she wanted me to just go ahead and hard wire it but i couldnt find a power wire. i found the constant and everything else but the power wire. I tried to get to the back of the fuse panel but dont really know where i would run a wire from and couldnt get the steering column apart to run a wire from the ignition switch. where else could I run a wire from? this is in a 2002 cavalier, and for now i just have the constant and power hooked up to the constant power wire in the car so the cd player doesnt turn off even when the car is off.
Username: Illuminator
Post Number: 223
Use the fusebox. Find a fuse that is only being powered while the car is on, then tap into it.
