Fuse blow
Username: Knuckles88
iam new to all this car audio stuff and i was wondering if a fuse blows then do you need to replace the power wire. thanx.
Username: Marley289
Post Number: 149
no, just replace the fuse. ive blown a few fuses and replaced them and i have never changed the power wire, and everything still works just fine.
Username: Goon
Post Number: 54
yeah just the fuse...the wire should be just find.
a fuse only blows if theres something wrong with the circuit. if you replace it with a new one and it blows again right away you need to get the whole electrical system checked out.
Username: Volfenhag1200
Post Number: 27
if the fuse keeps blowing then check the impedance. if your impedance is not wat it should be then you could be pulling to much power which will blow the fuses
