You know what sucks.....
Username: Hdubb
Farmington, Nm Usa
Post Number: 1255
whe the surround on your brahma comes undone from the cone. you know whats even better? when the return auth. form link doesnt work. i emailed them, my sub has given me a lot of tears. i renamed the brahma, it is now called the heartbreaker, you know what is kinda wierd, you see and hear about all of these brahmas that have been reconed, llike marshalls, and ive seen a lot of them on other forums, i think that adire might have a quality problem on some of these subs.....
( i know that no one will agree but, i have stated my hypothesis, so lets hear it)
what happen to your sub marshall?
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 534
I think the glue Adire is using just isnt strong enough. My spider broke loose from the basket. Then again...burping @25hz in a box tuned to 36hz will do that:-) The brahma is still an amazing sub though...i just figure they used the wrong kind of glue.
The great thing is that Adire has the 3yr warranty, and the glue coming loose is covered.
um... a dirty hooker
a vaccum
intake on a car
couple other things...
Username: Araknid
BOCA , FL U.S.
Post Number: 403
How long did it last before this happened?
Username: Hdubb
Farmington, Nm Usa
Post Number: 1257
um i tinkn it has been close to 8 months
