Speakers sizes
Username: Palya
Greece, NY USA
I got a question for the pros
i got a 1999 Mitsubishi Galant and the factory speakers are 4" , 7" -front 6x9" - rear.
Can i swap them for diferent size like 4x6 or 4x8 or any other sizes and also can i swap the rear speakers which are 6x9 for some other size?
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 172
sure, if you can get them to fit. easiest thing to do is use some MDF to fill the hole, then cut a new hole in the MDF to mount the speakers too.
they also make mounting spacers too
Username: Palya
Greece, NY USA
i can put different typy of speakers too right?
like sony in the pront and panasonic in the back or and other types right?
Stockbridge, GA USA
Post Number: 177
you can, but each brand has its high points and low points, so it might not sound very good.
